Well... replaced water pump but... no longer have a fan on the truck
Old 02-21-2010, 01:37 AM
  #21
neilownz's Avatar
That works if you still have it on with the belt. You're going to have to find a way to hold the pulley/shaft in place. Maybe could cut it off then drill it out or screw/weld/epoxy the thing to a plate, put it in a vise, and have a whack at it if the pump is garbage.
Old 02-21-2010, 01:48 AM
  #22
Black'Rado's Avatar
why not jus go elec fans? they can be done for really cheap
Old 02-21-2010, 08:55 AM
  #23
SUPERCHARGE's Avatar
Well... other than welding most of these methods have been tried. One day, i'll put a bunch of coat hangers around the holes, secure it with a vice and beat it till it's loosened. But honestly, after trying it without a clutch fan, i've noticed a small increase in acceleration. So i'll research and give myself a month to decide if i should go electric or not.
Right now, have a bigger prob... after testing my truck, no leak, but the battery isn't charging. Probably my fault though...new post for that prob.
Old 02-21-2010, 03:20 PM
  #24
neilownz's Avatar
E-fans are the way to go. Just check if you have a 28 or 34 inch radiator before purchasing anything.
Old 02-21-2010, 03:30 PM
  #25
BuyAmericanIron's Avatar
Don't use heat on the fan clutch nut or you will ruin it, and it does not take much. Use a clutch wrench or a big cresent and hit it with a 3 lb dead blow hammer a few times, in the right direction of course and it will come right off with no damage. Like posted before, you should have done this before you took the belt off, it would have been much easier.
ullose272
08-05-2016 02:05 PM
wrb002
08-31-2015 12:00 PM
InsaneDomestics
07-27-2015 02:42 PM
black6spdz
07-16-2015 01:32 AM
01sierraon22s
07-08-2015 11:26 AM
Quick Reply: Well... replaced water pump but... no longer have a fan on the truck
