Went try the new converter last night.....
Old 09-30-2004 | 06:51 PM
creederado's Avatar
12Sec5.3,
Its the Truck thruster not the Torque Thruster right?
I'm envious of your times, NA? I have a similiar setup, almost the same, except the High lift 212/218 and 4.10"s, 28 drag radials. I'm using the Torque Thruster 3.0str, pretty loose, I love it.
Are you still using the 99PCM? Resistors? any false knock? My godamn 99 pcm was cursed.
Nice times if those are your only mods.
Old 10-01-2004 | 07:58 AM
12sec.5.3's Avatar
BigKID- It doesn't actually flash to 3k, it flashes to about 2500 when the truck takes off. I didn't try on the track but on the street with the sportsman pro's it will only brake stall to ~2100.
Creederado- I'm not sure which one I have, but it had a little sticker on the converter that said "TRT 3000". That could mean either one to me. What is the difference?
Dude let me give you a hint, when you go to the track put some 26'' tires and you will pick up e.t.. reason b/c you will 60' better rev faster and cross the line at a higher rpm. I have the stock pcm and whatever else. I am getting a little knock retard and do need to get that taken care of.
Love what you've done with the truck. Good job!
Old 10-01-2004 | 08:15 AM
marc_w's Avatar
That's strange you're only seeing 2100 on the brake... I can brake my stock converter to an indicated 1,700-1,800 before I start to push/drag along.
Old 10-01-2004 | 09:59 AM
cablebandit's Avatar
9 Second Club
converter stall is gonna change with different hp/tq ...one guys 3000 stall is a different stall in another guys truck if it has more/less hp/tq
Old 10-01-2004 | 10:06 AM
marc_w's Avatar
Yeah - I didn't think it would be that drastic though.
I wonder if that 212/218 cam is healthy at those RPM's in a 5.3L.
My little cam wakes up just after 1,500rpm in my 6.0.
Old 10-01-2004 | 10:34 AM
JERRY2500's Avatar
14 Second Truck Club
12Sec5.3,
I wish i could of made it there, i wanted to see you run. I'll proubly make it there next week. I'd hate to see you change your name to 13sec5.3 j/k
Old 10-01-2004 | 11:32 AM
12sec.5.3's Avatar
Originally Posted by JERRY2500
12Sec5.3,
I'll try to make it to the track tonight and see what I can do. I have a couple of things i want to try.
Old 10-01-2004 | 12:13 PM
JERRY2500's Avatar
I'm going out of town for the weekend so i'll have to wait till wednesday, But my buddy will be there with his lime green 70 chevelle. Check it out, heavy *** car running 10.40's. He finaly got it running right.
jscherbs
03-24-2017 07:20 PM
Go5.3tt06
25
09-04-2016 10:25 AM
TAPyvehc93
01-08-2016 10:47 AM
jtphelps289
09-11-2015 06:37 PM
06 4.8
09-11-2015 10:36 AM
Quick Reply: Went try the new converter last night.....
