Went try the new converter last night.....
12Sec5.3,
Its the Truck thruster not the Torque Thruster right?
I'm envious of your times, NA? I have a similiar setup, almost the same, except the High lift 212/218 and 4.10"s, 28 drag radials. I'm using the Torque Thruster 3.0str, pretty loose, I love it.
Are you still using the 99PCM? Resistors? any false knock? My godamn 99 pcm was cursed.
Nice times if those are your only mods.
BigKID- It doesn't actually flash to 3k, it flashes to about 2500 when the truck takes off. I didn't try on the track but on the street with the sportsman pro's it will only brake stall to ~2100.
Creederado- I'm not sure which one I have, but it had a little sticker on the converter that said "TRT 3000". That could mean either one to me. What is the difference?
Dude let me give you a hint, when you go to the track put some 26'' tires and you will pick up e.t.. reason b/c you will 60' better rev faster and cross the line at a higher rpm. I have the stock pcm and whatever else. I am getting a little knock retard and do need to get that taken care of.
Love what you've done with the truck. Good job!
Originally Posted by JERRY2500
12Sec5.3,
I wish i could of made it there, i wanted to see you run. I'll proubly make it there next week. I'd hate to see you change your name to 13sec5.3 j/k
I'm going out of town for the weekend so i'll have to wait till wednesday, But my buddy will be there with his lime green 70 chevelle. Check it out, heavy *** car running 10.40's. He finaly got it running right.
jscherbs
03-24-2017 07:20 PM
jtphelps289
09-11-2015 06:37 PM
