were to begin
were to begin
i just purchased a 2006 silverado crew cab short bed with only 21,000 miles on it. would like to know were a good starting point is on some mods. this is my daily driver thanks
Mr. Obvious
id do the mods in this order
mailorder tune or dyno tune if available
cat back exhaust
long tube headers w/ off road ypipe
cold air intake
electric fans
underdrive pulleys
6.0L swap w/ a cam and valve train
fuel injectors and fuel pump
p&p heads
intake manifold or supercharger or turbo
nitrous
cat back exhaust
cold air intake
electric fans
underdrive pulleys
p&p heads
nitrous
For a daily driver with a little pep in its step i'd recommend a nice sounding exhaust, intake w/ tube, and a tune for the first few mods.. After that maybe headers, stall and cam with new valve springs of course, throw a ported ls6 oil pump in the mix for the cam and you'll be putting down great #'s.. I think being an 06 you'll have electric fans already btw.
-Lurius
-Lurius
I'd start with spelling/grammar.
WHERE = the here and there one :p
I'd go with a tune and full length headers first. depending on how far you want to go with it, it may or may not be worth a tuner instead of tune.
Mr. Obvious
you have roller rockers from the factory
gibson headers are no better than the stock manifolds, unless they came out with a long tube setup
get some pacesetter headers and a pacesetter offroad ypipe
then order a tune
oh and i forgot to add to the list a built trans, stall, gears and a lsd
then order a tune
