What about letting this guy do my cam?
Old 03-05-2008, 08:35 PM
03GMC's Avatar
Originally Posted by turbo_camaro
Lol!!!!
Told you I would post on here!!
Old 03-05-2008, 08:44 PM
yeah it's me. I was on here looking for torque specs and tips to make it go by faster. I've swapped cams in my camaro plenty of times but never on a 5.3. Do the 5.3 have the lifters that lock in place in the trays like the ls1?
Old 03-05-2008, 09:10 PM
03GMC's Avatar
Yes, from what I've read they do lock into place. Some guys use pen magnets or dowel rods to hold the up though.
Old 03-05-2008, 10:02 PM
xlcooplx's Avatar
yep, dowel rods are cheap insurance IMO.
Old 03-05-2008, 10:22 PM
Also make sure and use some loctite on the cam bolts and on the cam retainer plate.
Old 03-06-2008, 09:49 AM
03GMC's Avatar
So all I really need is a cam bolt (anyone have the part number?), water pump gasket, someway to hold up the lifters, oil, coolant and some loctite?
Old 03-06-2008, 10:04 AM
Hunt&Fisherator
silver-mod-o's Avatar
I re-used EVERYTHING in my motor... all I swapped was the cam and springs... you dont need the pump gaskets or the bolt... (but the bolt does make it easier to get the pulley back on.)
Old 03-06-2008, 12:10 PM
03GMC's Avatar
So do I need to replace the valve springs or the valve seats with dual springs? This guy that works at chevy wants to do it for me and was telling me with dual springs you have to replace the valve seals.
Old 03-06-2008, 12:21 PM
Hunt&Fisherator
probably not the seals... do the springs and retainers and pushrods along with the cam... you wont be running a ton of lift, you'll be good to go.
Old 03-06-2008, 01:01 PM
03GMC's Avatar
Well this guy works for chevy and does cam installs quite often. He said if I run dual springs I need new valve seals or it will burn oil nasty.
Quick Reply: What about letting this guy do my cam?
