What advance are you guys using? 212/218
Old 10-05-2009, 10:17 PM
Resident Retard
BlackGMC's Avatar
Originally Posted by NoShow
BTW, it's an LS6 with truck intake, long tubes, a 3.73, stock TC. Shooting for 440hp under 6000 rpm
with a 212/218 cam.... I think you will be about 100hp short...
Old 10-06-2009, 07:53 AM
NoShow's Avatar
Uhhh...An 04 LS6 is 400+ hp out of the box
That black pickup is sheeaaarrrpp. I'dve tried to find one if they were'nt so hard to keep clean. What do you get for HP with the mods in your sig??
Old 10-06-2009, 08:15 AM
Resident Retard
BlackGMC's Avatar
If you talking about a 400+ on GM's fantasy Engine dyno then your right, but real world chasis dyno, i seriously doubt you will come close to 400... No offense...
thanks, with the mods i have i put down 318, i believe my enging puts out 285hp according to GM... Dyno numbers don't mean squat... IMO track times is what counts...
Old 10-06-2009, 08:34 AM
GMCtrk's Avatar
He's talking about flywheel power. The ls6 makes over 400 hp right out of the box
Old 10-06-2009, 08:38 AM
charcoal03silvy's Avatar
To the wheels, the 400 is
Out of the box that is.
Old 10-06-2009, 09:04 AM
Resident Retard
BlackGMC's Avatar
Oh flywheel HP?? Sorry 99% of the people talk rear wheel hp because that is actually measureable in most cases, I don't think I have seen anyone strap an engine to a engine dyno before on this website... But hey if that floats your boat, engine dyno away... I still don't believe it will but down 400 right out of the box, sorry I am mr. Negative
Old 10-06-2009, 09:39 AM
Resident Retard
BlackGMC's Avatar
Sorry about ranting in your post, but back on topic. IMO I would start with advancing 2 degrees and see how that feels, then advance or retard it from there. Since your after more power under the curve or at least that is what it sounds like I bet you will end up with roughly 4-5 degrees of advance
A couple of questions thou. What is the CR of a stock LS6? Also is the LS6 a motor that likes to rev or is that the LS2?
Old 10-06-2009, 11:20 AM
PT's Slowest Truck
budhayes3's Avatar
My dad staps every engine his builds on to an engine dyno, and he builds some really stout engines....too bad he doesn't do any GENIII stuff :bang; If I was more of a guru, and had money that I could quit my job, I'd spearhead his LS program...ahhh daydreams.
Old 10-06-2009, 11:23 AM
PT's Slowest Truck
budhayes3's Avatar
I agree, I'm guessing 4* of advance but I'm really not sure. Comp grinds 4* of advance into many of their LS cams, I'm curious why this one has 0
Old 10-06-2009, 07:02 PM
NoShow's Avatar
The LS6 has a 10.5:1. And one reason for talking flywheel hp is that you can figure out what injectors you need, amongst other things. All the books and websites I've seen that compare different cams and bolt ons show flywheel numbers, so it's a nice way to compare without worrying about whether one car has an aluminum driveshaft or 4L80 vs 60 etc. etc.
If you have 318 to the asphalt with a 4.8 you know what your'e doing
BKnBLK05
12-28-2015 08:52 PM
Go5.3tt06
09-12-2015 09:29 AM
fillpot
07-26-2015 07:21 PM
lxcoupe
07-21-2015 02:12 AM
GM-only
07-19-2015 10:48 PM
Quick Reply: What advance are you guys using? 212/218
