What Cam....5.3L
#31
formerly 1BADC10 (12/14/2011)
Went from a Comp 216/220 .525/.532 to their 224/224 .568/.568 cam (both w/ 114lsa). I haven't had much drive time on the second cam yet, as my 4L60E's 3/4 gears are not engaging. I have taken it for a few WOT bursts, and mild 2nd gear cruising. I will say that I haven't noticed much of a difference as far as idle quality and stop&go driving. Performance-wise is different as I can make the truck go sideways from a 20-roll as I had not been able to do before (on the same tune), even with new tires on the back end. I have a 3000 stall speed TC. I do NOT notice any hesitation at RPMs lower than 3K. Maybe the 4.10s help a little, but a higher stall speed tends to put you higher in the rpms, thus being in the powerband a lot quicker than a stock TC.
Since you're a Comp dealer, look at Comp's grinds, and get something comparable to TR's 220 or 224 cams. TR's cams have been tried and proven to run well in 12s trucks w/ supporting bolt-ons & weight reduction.
#32
Yah im gonna call com cams and see if they ahve soemthing in and around the 220 .580 sorta range...I dont really want a custom grind..cause for the like 600 I can get the thunder racing one with the springs and rods.....probably cheaper than a custom grind Comp....
#33
Alright...this the one look about right...2600-3000 tall
99-TR220/220-112 Thunder Racing Custom Camshaft - 220/220 .551/.551 112 LSA 1500-6500 RPM Power Band. Computer Tuning Required with automatic transmission cars. A very well balanced camshaft that makes excellent power across the entire RPM range. Due to the fast ramp rate of this camshaft, the use of
lookign good?
lookign good?
#35
11 Second Truck Club
lookign good?
lookign good?
#36
Banned
1 Post
i used the 216/220 for a long time and had very good out come with it and had some good dyno numbers,but in the last few mouths i have been working with the tr220 but i would don't like te lift,a friend of mine that builds and ports motors had com cut a cam and we have seen really good results in an cc cab truck 6.0 fully ported 317 heads and all bolt ons and a tune no,not a dyno tune either the truck ran a best of 12.64 at 109 with mt drs.
i think the tr224 is a little big for a 5.3 unless you are going with at least 4.10 gears and a 3200 stall,and a dyno tune.
the cam that the cc has is a 216/220 565/570 on a 114+2 and the truck sound stock unless you be around racing a while you will not know
#37
ive got a 5.3 ltr also. its a 99. i found a deal on this cam. i really want more low end andmid range due to off roading a nd towing. i have a 2600 stall with 3.73's
214/224 dur. 523/535 lift. 114lsa does this sound good for low end and mid range power?what will the idle be like?
