What is code P0315.....?
Not sure what this code means
P0315 Crankshaft Position (CKP) System Variation Not Learned. I tried removing it with autotap and it will not remove the code. Any ideas?
Here is a good site for defining codes
Http://www.automotiveforums.com/t95876.html
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
Formerly one92rs
![Talking](https://www.performancetrucks.net/forums/images/icons/icon10.gif)
did you just install the tune or another pcm. if so you will need to do a relearn procedure for it.
http://www.nelsonperformance.com/faqs/passkey.htm
EDIT: Nelson pcm has been installed for just about 2 months, and now im getting this code.
Originally Posted by JERRY2500
Dont go to the above site there is a trojan virusautomotiveforums
EFIlive has a crankshaft position relearn program,you basicly clear all engine codes and follow the instructions on the screen.That takes care of the problem.Or you can go to someone with a Tech tool to do the samething.
12 Second Club
