What is the compression ratio for my 2001 Suburban?
thunder550, So using 89/ 87 would be ok? The only performance done on my 5.3 engine is adding JBA Headers, Open air intake, and an exhaust system. What can increase my compression ratio? Just curious.
The owners manual will tell you what octane fuel to use. If I remember correctly it says to use fuel with an octane rating of 87 or higher.
To change your static compression ratio you need to make changes to your engine (mill the heads, thinner head gasket, etc) or your cam selection can alter effective compression ratio (there is an actual name for this but I am having brain lock) by changing your camshaft durations.
High on diesel fumes
There's two types of compression ratios. Dynamic and static.
Static is just your bottom dead center (largest) cylinder volume divided by your top dead center (smallest) cylinder volume. The only way to change this is to change the relationship between these two values, like changing piston design, or changing to a cylinder head with a different sized combustion chamber.
Dynamic takes into account valve events. Most cams don't close the valves directly at bottom dead center, so there is a little bit of compression lost between the time the piston starts its upstroke and when the valve actually closes. You can change your dynamic compression ratio by changing valvetrain components, like a cam or rocker arms.
The SCR of my engine is 9.4:1, but the DCR may only be 8.2:1. DCR is always less than SCR.
Nothing that you have done so far will change your compression ratio.
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
5 year bitches!
26gallon tank difference between 93 octane and 87 is 6 bucks!!!!!!!!!!
Sea Foam is supposed to be good (O'Reilly and others carry it). It's about $6 a bottle here. It has other uses,too...read label.
BG 44K is supposed to be very good at cleaning the fuel system and valves/combustion chamber. It's not avalable at regular AP stores as far as I know. Check yellow pages. It's $15 or more per can.
