What do i need to put a 08 intake manifold on my 04 chevy
#21
yeah guys but here's the thing...
I'm putting in a new motor with cam and full bolt-ons i don't know what it runs...
but with extremly big cam that i'm goin to use a few peopl said to use this intake or the fast intake... and i don't feel like paying almost a grand for the same thing...
#26
But there was a thread awhile back on how they couldn't get the car TB to open all the way on the truck. The car or vette on opens quite a bit faster but that was the doozy in the equation.
#27
the car t-body works great. and yes it does open faster than the truck. throttle response is much better.
#29
the one i had was ported(bought it that way) so it could have been an issue but it works fine on the tbss i got it off of. even put it back on to verify. he had the car style also so i used it and have yet to have a problem with it. doing research i found a few others that had problems with the truck style also. mine would open fine but would go into rep mode at 4500 or so. searching the tbss forums the guys running maggies were having the same problems as well as flaco on here when he first got his put together. it would only act up during high airflow and was blamed on the weaker spring in the throttle body allowing the incoming air to move the blade. that is what was triggering rep.
#30
one note on stepping up to an even bigger TB on this intake. i noticed sticking my fist down inside the manifold that it seems to be tapered and is a noticeable amount smaller down inside then it is at the throttle body end. not sure a bigger throttle body would do anything being it still has to pass through this smaller section.
