What exactly is a Servo??
If you're talking about servos in the auto trans, they are nothing more than a piston with a lip seal around the edge that fits in a bore, like an engine piston in a cylinder. When trans fluid acts on the servo, it most likely applies a band to hold a drum.
So in other words, it just applies linear actuation to something.
you have a band that surrounds a drum to turn it. a stock servo applies let's say 40 pounds pressure. a vette servo in the same application will apply 60 pounds pressure. thus holding the band tighter on the drum to reduce slippage. it does this by the amount of force and coverage area. sounds good. i think that;s about the best explanation i can come up with. there are some tranny guru's here that can explain it better.
Tigger Welder
10-01-2015 08:41 AM
lycominghunter
08-15-2015 12:26 PM
