What to expect from a 80MM TB
Old 09-07-2005, 02:13 PM
Default What to expect from a 80MM TB
Hey you experts, what should I expect from installing a 80MM Throttle Body on my 5.3 truck? I'm already modded w/ cold air, engine-back custom exhaust, MAF, Nelson Tune & Shift Kit.
Is it worth it? Will I feel the diffrence?
Old 09-07-2005, 02:15 PM
Fogle07's Avatar
i wouldnt buy one new. i got one on my truck and you cant really tell a difference with it on there. if you can get one for a good deal then id say do it. other than that dont
Old 09-07-2005, 03:12 PM
BadAssChevy327's Avatar
from wha i experienced on motors with just bolts they do **** , actually hurt you . my buddy has a 98 malibu , ran 15.1 . we did a lot of stuff to it . but he got a tb not sure what size and went back to the track couildnt break a 15.5 , hurt him so bad low end i guess . my other friend has a SI civic , runs 15.5 , after his skunk 2 intake manifold and tb he hits 15.7 , he put the stock tb back on to try it and hasnt been back yet . but i kno thats a import but my buddys malibu the 3.4 is set up like are 5.3 if u think bout it . idk thats just my thought i wouldnt bother with one till i have internals or power adder
Old 09-07-2005, 03:43 PM
Bad_Apple's Avatar
I put mine on my truck when I had a lot of bolt on's and I think it actually hurt performance. So I took it off and put my spacer back on and it felt stronger again. but when i went with the Procharger I had them put it back on.
Old 09-07-2005, 04:32 PM
zippy's Avatar
if you're not flowing enough air to make the stock throttle body be a restriction, you're wasting your time and money. at the power level you're at, you'll likely lose more than you'll gain.
Old 09-07-2005, 04:42 PM
chevyerett's Avatar
Why does it cause a lose in power? Doesn't make sense. Of course I've been around flux remover fumes all day...
Old 09-07-2005, 04:48 PM
because so much more air is coming in the velocity is bein slowed down of the air flow and its causes a turbulence , most of them help in the upper rpms becuase theres so much more vac there pullin air in .
am i right guys
Old 09-07-2005, 05:20 PM
Just keep your stock TB. Unless your going to install a twin turbo kit or equivalent forced air induction.
The stock TB has plenty of CFM of flow to handle most power adders as well.
Jim
Old 09-07-2005, 08:42 PM
v8
17,16,15,14,13,12,11 Drvr
before i had nelson tune for the bbk 80mm t/b i lost 4/10 of a second at the track, but after we tuned for the t/b i gained 1/10 and 2mph over stock t/b. Same night testing.
On the dyno it showed 10hp gain. But like i said after nelson tuned for it.
Old 09-08-2005, 07:48 PM
OUT2WIN's Avatar
I had mine in my 99 5.3 and I thought it helped. It was the only difference between mine and a buddy's truck and I would always have lower track times.
I got one I pulled off my 99 when I sold it that I will sell ya TorqueWrench.
Quick Reply: What to expect from a 80MM TB
