What fuel pump for 500ish horsepower?
What are the fuel pump options for a 2000 Silverado making around 500 horsepower (crank). My friend has an ATI, and his fuel pressure starts to drop off right around 5000rpm. Is the Walbro intank stuff a direct replacement? What about an inline? Thanks.
blownerator
and inline would be better IMO. the walbro is a drop in, but you need to replace the connectors.
blownerator
Originally Posted by parish8
i single inline walbro gss340m is easy, cheap, reliable and will more than do the job.
i pushed mine to what had to be close to 600rwhp with no presure drop and it only cost about $120, more like $150 or so with a relay and some good termainations.
single digit dreamer
i will look for a pic, it was an ext cab truck and there was a nice strait section of line right under the extcab part of the truck. i dont have anything like that on my new truck, not sure where to put it on a RCSB
edit...i just looked for that pic, cant find it. anyways, if you have an ext cab just look at the strait section of line right in front of the fuel pump, real easy to put it there, with a RCSB i am not sure where you would put it.
If you are going to be running more than about 50 psi of fuel pressure under boost, then you should look to the Walbro GSS342m. This is their high-pressure version. Also, you could add a pump inline by the filter. I like the NOS pump for their stage II upgrade on their dry systems. I think they are like $180 or so and they come with brackets, a nice foam sock for quiet them down, fuel lines, etc.
GXPJAY
02-13-2022 08:15 AM
05GMC4.8
08-07-2015 09:55 PM
Mossyoakglock
07-17-2015 08:30 AM
