What has everyone paid for their LS1 fans?
So if I go to the junkyard do i just pull the fans off the radiator and unplug a plug or do I have to cut some wires and make my own harness(Ill probably get one from nelson) or what?
TTT the nelson harness plug directly into the ls1 fan plugs?
I got my efans from ebay for 88 shipped last week. Bryan Herter DOES have the same harness Nelson has for a bit cheaper price...fyi.
Pat
do 05 truck fans bolt right up also? dont you have to get a bigger radiator?
"We do not suggest this for a full-size truck application : Mechanical fans almost always extract more CFM of air than any electrical motor. Since a truck is typically twice the weight of a car and sometimes towing or hauling, they generate twice as much heat through the radiator, and the electric motors cannot produce sufficient CFM. Also, the dimensions of these fans don't cover sufficient area on a full-size truck radiator since a truck's radiator is normally 25% larger than a high-performance car. "
thats what ls1 fans on ebay say...is it true? anyone have problems with this?
do ls1 fans just bolt right up? or do you have to make a custom bracket?
thanks
jerome
thanks
jerome
