What The Hell Did I Get Myself Into?!
Here are the list of parts going into this project!
LS6 Intake
97/98 Corvette Fuel Rail / Regulator
LS1 Throttle Cable Bracket
LS1 28.8 Injectors
LS6 Intake Bolts
ARP Crank Bolt
LS2 Timing Chain
LS7 Lifters
Comp Cam Hardened Pushrods
GM Head Bolts
LS1 Style Injector Connectors
LS6 Intake Gaskets
GM 5.3L Head Gaskets
5.3L Heads w/ 3 Angle Valve Job, Corvette 2.00 Intake & 1.55 Exhaust Valves, Milled .030, Valve Springs .600
Katech Rod Bolts
LS1 Water Pump
Lingenfelter Performance Eng Oil Pump
Fabricated Idle Pulley Relocation Bracket
Water Pump Gaskets
Timing Cover Gasket
Front Seal
TR228R 112
Custom Fuel Lines
Click Here for my progress in pictures then on "Projects"!
LS6 Intake
LS1 28.8 Injectors
LS6 Intake Bolts
ARP Crank Bolt
LS2 Timing Chain
LS7 Lifters
GM Head Bolts
LS6 Intake Gaskets
Katech Rod Bolts
LS1 Water Pump
Water Pump Gaskets
Timing Cover Gasket
Front Seal
TR228R 112
Custom Fuel Lines
niiiiiiiice
i'm swappin in my t-56 this next week jsut waiting on the pedal to show up
i already got the rest of the parts and i'm building the tranny tonight, billet keys all the way around bronze pads on all 4 forks, carbon kevlar blockers and a steel 3-4 fork
oh yeah the pro 5.0 should show up tuesday
The valve cover are stock ones that I painted up. I ground down the tabs that are not in use and made little brackets to move the coils up an inch. I am going to run two passenger side covers and delete the PVC system. Then going to run twin oil cap breathers with a cross over tube to balance the pressure. I will have pics of course at the ind of the build if I am confusing anyone.
Here are the breathers I am talking about!
