what hp to expect
Old 03-29-2009, 11:21 AM
20inch8lug's Avatar
def do a tune, i am goin to meet with justin from black bear next month. every1 says best mod for the money by far.
Old 03-29-2009, 12:15 PM
jerrymaister's Avatar
which gear will be best? and cams? would and ls6 cam be good for my truck and what intake.
Old 03-29-2009, 01:27 PM
just treat it like a heavy FBody. Thats basically what we are...lols
I have the patriot LS6's, z06 cam, 1.85 rockers, intake, and full exhaust and like how it runs now.
Transmission is next, along with a converter.
I would put some 4.10s if you plan on keeping those 22's.
Old 03-29-2009, 07:39 PM
so parts are interchangable? like can i use a ls6 cam and heads on my 4.8?
Old 03-29-2009, 07:54 PM
Baltimore Whore
Mangled03gmc's Avatar
Yes, parts are interchangable. The ls6 cam is a nice cheap upgrade, will make a power difference.. I wouldn't go putting the ls6 heads on the 4.8 unless you have them milled to bring the comp up on your engine.. Like stated, a tune is going to be the best bang.. But you really should ditch the shortys and get some long tubes on there. If you have some money to spend I would invest in some gears and a posi unit... Between them few mods, you should bust your friend pretty good. Also the big rims are killing you..
Old 03-29-2009, 08:48 PM
so for now gears, shift kit and servos, 1.85 rockers and ls6 cam plus tuning should be good? how about a trail blazer converter is that a good upgrade?
Old 03-29-2009, 09:45 PM
Truck Sponsor
Wheatley's Avatar
personally,I would scratch the 1.85 rockers off the list.
cam,higher stall torque converter,definaly gears and let me know when you are ready for a tune if you choose to come to me.
Nice truck by the way,I have the same thing
Old 03-29-2009, 10:23 PM
sure i've heard alot of good things about you. but which gear should i get considering that its my daily driver
Old 03-29-2009, 10:28 PM
Baltimore Whore
Do you have 342's now.. If you are scared of being hurt by gas mileage 373 would do you good. What are you over all goals for the truck??
Old 03-29-2009, 10:32 PM
its a stock rear end. i don't want a super fast truck just faster than what it is now. i know i gotta get rid of the 22" just to start off.
Quick Reply: what hp to expect
