What hp#'s should I put down?
I have an 03 Chevy 5.3 EC with mods that include (and/or will include), true duals w/magnaflows and QTEC's, K&N FIPK, vigilante verter, 2800 stall, mild comp cam, and throttle body spacer. What kind of numbers should I see when I dyno it three weeks from now? What others mods should I consider for now? What kind of 1/4 mile times might I see?
Well, you can ditch the throttle body spacer, its a paper weight. You have the converter, are you using a transgo shift kit, and vette or billet servos, if not, get the set/kit. This will allow you to remove your torque management and change your downshifts. Get that tune in with the cam. Really, the big reason you might see the power that you will is the cam. Get some headers, and a set of electric fans.
I put out 279 hp to the wheels with the mods in my sig, not headers/ no cam, at least not yet, headers soon to come. What rear end you running, gears? Locker or posi or LSD? and you might want to add a trans cooler.
