what kind of power to expect
How much more power to be gained if I add e-fans and asp pulleys? The fans are on thier way and the pulleys will be on their way in a few days. I'm going to install them at the same time, will I notice a SOTP difference? Also will I crader my alt. with these mods added together (I don't have a system and I'm getting the alt pulley with the crank pulley)?? Thanks
You should get a noticable differance with that set up. You should get around 8 to 10 hp from the fans as well as better gas milage and throttle responce. The pullys should help out in throttle responce and gas milage as well. Not much of a hp gain, a little tho. If you are not running a stereo system you should not have a problem with the alt.
LSX-81-SIERRA
08-31-2015 05:52 PM
