What mods to Maximize MPG on 5.3?
Old 03-17-2010, 02:23 PM
  #21
Wearin' da big hat
00ChevyScott's Avatar
Not on a truck with big tires.
Old 03-17-2010, 02:56 PM
  #22
Where's the Beef?
viciousknid's Avatar
The exhaust opens up your top end. Stock exhaust helps your bottom end. The problem is your truck is a heavy pig and it is hard to get it moving. You need more low end power to get it rolling which will help your mpgs.
Might consider a small duration cam.
Old 03-24-2010, 08:40 AM
  #23
drperry's Avatar
Re-gearing to 4.10s will help mileage as well.
Less work to get the truck rolling...
Old 03-24-2010, 12:28 PM
  #24
GFYS and STFU
Spoolin's Avatar
Re-gearing to 4.10's will help mileage??
Old 03-24-2010, 03:24 PM
  #25
drperry's Avatar
It will with a lift and bigger tires.
Old 03-24-2010, 04:14 PM
  #26
Manbearpig's Avatar
Brick mod behind pedal
Old 03-24-2010, 05:56 PM
  #27
faster4whl's Avatar
Would I notice going from 3.73s to 4.10s more power and better mpg?
Old 03-24-2010, 06:05 PM
  #28
ForcedTQ's Avatar
Exclamation
More multiplied axle torque? Yes. Better highway MPG? No. not without lowering the 4th gear (overdriven gear) ratio in your transmission.
Old 03-26-2010, 04:23 AM
  #29
drperry's Avatar
How so?
If the motor doesn't have to work as hard, it's not going to have to use as much fuel...
Is he going to get back to stock mileage? Not likely... But it will get better, even on the highway.
The right gearing will bring the RPM's back down on the highway, the trans will last longer, since it won't always be changing gears to turn the heavier wheels and tires...
Though, it's not likely to be worth the money to DO the gear change vs. fuel savings...
Oobray
06-13-2022 03:38 AM
B.love18
09-21-2015 08:31 PM
thewrx
08-12-2015 08:28 PM
RoidedSS
08-11-2015 11:51 AM
Choda
07-21-2015 03:47 PM
Quick Reply: What mods to Maximize MPG on 5.3?
