What are my options for what I want in a motor?
Old 09-25-2012, 12:37 PM
nonnieselman's Avatar
I think you meant 10 guys with have 11 diff opinions.. theres always one that cant make his mind up
Old 09-25-2012, 12:39 PM
99-00 iron heads weird crank.
01-04ish good but smaller rods
04ish-07 classic are the chosen ones with good rods.
08+ are 52x reluctor ring for the crank signal
99-07 classic are 24X.
LQ9 are the higher compression 6.0s with 9.9-10.0 CR vs LQ4 with 9.4CR
Old 09-25-2012, 12:57 PM
WhiteJimmy's Avatar
This is an ad I found locally for a 6.0....
"I have a 2009 ly6 out of a gmc van vin# 1GTHG39K291105411 with 82k miles it has everything from intake to oil pan minus the coil packs it is a iron block 6.0 with the ls3 823 heads that are rectangle ported not cathedral like all the other LS style heads..."
Asking $3500..seems kinda high
I just want to thank y'all for the help so far.
Old 09-25-2012, 01:18 PM
You can get a brand new LQ4 for 3200 around here
Old 09-25-2012, 01:23 PM
Custm2500's Rude Friend
1FastBrick's Avatar
An LY6 is the newer style 6.0 that replaced the LQ4. I believe it has Displacement On Demand option which is crap. There still much to expensive.
You should be able to find an LQ4 complete in the $1000-$1500 range.
Old 09-25-2012, 02:00 PM
TheJavelin's Avatar
Has the L92's though IIRC.
Old 09-25-2012, 02:41 PM
1FastBrick's Avatar
Yes as the Ad stated with the LS3 head casting numbers.
Old 09-25-2012, 04:36 PM
TheJavelin's Avatar
Didn't read that....
TXsilverado
11-26-2015 10:54 AM
kyle's v
10-04-2015 12:37 PM
chevy6.0fan
08-20-2015 07:10 PM
Quick Reply: What are my options for what I want in a motor?
