What needs to be changed to swap a 5.3 in place of a 6.0L?
Old 06-14-2010, 01:14 PM
team39763's Avatar
Default What needs to be changed to swap a 5.3 in place of a 6.0L?
I got a buddy that needs a motor for his 2500HD. He just needs an inexpensive replacement and 5.3L's seem to be popping up left and right for cheaper than a 6.0L. I know everything will swap over, but does the tune need to be changed? Will it atleast run with the stock 6.0L tune? Thanks.
Old 06-15-2010, 07:08 PM
whitegmc2002's Avatar
if he is not in a hurry hopefully next weekend ill be swapping a 6.0l in my truck and will have a 5.3 for sale with the computer that has a tune in it motor has 99000 miles. he would have to but an harness for his trans to work, bc i would think he has a 4l80e.
Old 06-15-2010, 07:20 PM
nickleahy23's Avatar
Why would he want to downgrade to a 5.3 in a heavy *** hd? Tell him to sell the truck for a half ton since he must not use it to tow much, or to save up for a 6.0..you can find them for 700-800..check car-part.com
but if he insists on throwing a 5.3 in, you would need to put the flex plate from the 6.0 on the 5.3...that should be all that you need to do and everything else will bolt up..he will use the same harness that is in the truck already so he wont have to **** with his trans..you can even run the 6.0 tune on the 5.3 i believe..worst case just get a blackbear tune or a local live tune on it..
Old 06-16-2010, 11:20 AM
team39763's Avatar
He wanted a 6.0L, but he really didn't care if you we had to drop in a 5.3 if the 6.0L was available. I don't think he tows much with it. It's just a good looking truck that he cruises in. I found a 6.0L with 130,000 miles on it, but I don't know if he'll go for that. I'll check and see.
Old 06-16-2010, 11:28 AM
pasadenaman's Avatar
What year 2500? Don't go to 5.3 from a 6.0. Youwill be talked about for years to come on here.
Old 06-16-2010, 11:32 AM
Wearin' da big hat
00ChevyScott's Avatar
I highly doubt he cares
Old 06-16-2010, 01:29 PM
team39763's Avatar
I don't care if people talk about me.LOL. It's my friend's truck not mine. He was just in a hurry to get his truck back on the road. But I think we found a 6.0L that he can afford and he might have enough left for a cam too.
Old 06-16-2010, 01:49 PM
MustangPunk's Avatar
To answer your question, yes it will run on a 6.0L tune, prolly pretty rich, and be doggy as hell. I would get a 5.3L tune asap..
Old 06-16-2010, 10:24 PM
PT's Slowest Truck
budhayes3's Avatar
What year is the 2500? If it's a 99-00 he will need to buy a crank spacer to bolt up to the 4L80E, as those years had a longer crank and did not use the spacer that the later years do. It will run on the 6.0 tune, but I wouldn't leave it like that permanently, so factor in the price of a tune to the swap.
Old 06-19-2010, 06:06 PM
team39763's Avatar
I think the truck is a 05, but he says he found a 6.0L for it already. Now I'm trying to see if I can get his old broke 6.0L so I can use it for my next build.
Quick Reply: What needs to be changed to swap a 5.3 in place of a 6.0L?
