What is this plug on the back of the intake manifold?
Old 12-06-2006, 12:56 AM
High on diesel fumes
thunder550's Avatar
Default What is this plug on the back of the intake manifold?
New SSR intake manifold....what is this red plug? It looks like a place where the brake booster hose should go, but it doesn't look like a hose fitting??
Looks like ASU's server is down - I posted a pic, if you can't see it check back again soon.
Old 12-06-2006, 05:20 AM
5.3 racer's Avatar
it's a shipping plug, pita to get out. you'll need the nipple out of your original manifold.
Old 12-06-2006, 08:14 AM
thunder550's Avatar
Cool, thanks.
Old 12-06-2006, 08:18 AM
Nick™'s Avatar
it's just a plug, reuse your's from your intake manifold... it's very easy to remove if you look at it, here's a hint - the best way to describe how it's retained is that it's the same style as the fuel line disconnects, you can get it with a pocket knife or small screwdriver
Old 02-26-2007, 01:10 AM
worm556's Avatar
I have a similar question. I got the smaller plug out, but how do I get this plastic ring off?
On the left is the plug from the manifold. On the right is the plug I need to get in there for my brake booster. Is it the correct plug?
It seems to me if I could that ring off it would fit.
Old 02-28-2007, 01:34 AM
worm556's Avatar
Anyone know? I want to just pry it out, but don't want to damage my intake manifold either.
Old 02-28-2007, 09:36 AM
thunder550's Avatar
The one you picture on the right looks kinda like the one that goes on the top of the intake manifold for the PCV system.
Old 02-28-2007, 05:30 PM
worm556's Avatar
I just checked my intake, there are no other plugs like the one on the right in the above picture. So i don't think its part of the PCV system.
Thunder550: what is that hose next to the shipping plug in your picture, does that go to your brake booster?
Old 02-28-2007, 05:37 PM
thunder550's Avatar
The one next to it goes to the top of the manifold, where there is a connector that looks like the one on the right in your pic. That's the PCV line.
Old 02-28-2007, 05:43 PM
worm556's Avatar
Where did you plug in your brake booster hose?
Quick Reply: What is this plug on the back of the intake manifold?
