at what point do you outgrow single exhaust?
Old 02-05-2010, 01:34 PM
TXsilverado's Avatar
Default at what point do you outgrow single exhaust?
Im fixing to either have a new Y pipe made, or completely redo my exhaust from the headers back…
At what point do you outgrow single exhaust? I have a 5.7 LS1 with patriot stage 2 LS6 heads, 231/239 111+2 cam, a ported fast 90mm intake, pacesetters, functional ram air and full bolt on’s all the way around it. Last time on the dyno it put down 430 to the ground. Since then ive added the ported fast 90mm. I know I am leaving some power on the table with my current Y pipe. It was the first gen pacesetter setup and the drivers portion of the Y pipe T’s into the passenger side instead of merging into the exhaust as a Y. here are some insane paint skills for illustration
I can either build the Y pipe that I want to free up some power, or go for a true dual setup with an X and some 18” long dynomax bullets (biggest they make). Am I making enough power to justify a 3” true dual x-pipe setup?
Old 02-05-2010, 01:44 PM
Wearin' da big hat
00ChevyScott's Avatar
Why don't you just swap to the new pacesetter Y pipe? I think mine merges just like how you want it.
Old 02-05-2010, 01:53 PM
i would have to take it to a trans shop anyways...band clamps suck. its just as cheap, if not cheaper in the end to just pay someone local to do it.
Old 02-05-2010, 01:58 PM
Resident Retard
BlackGMC's Avatar
Personally i would run 3" off the collectors, then merge into a 3.5" ypipe, then run 3.5 for the rest of the exhaust... That should flow plenty.
Old 02-05-2010, 02:03 PM
but i just got this dang 3" DMH e-cutout lol.
Old 02-05-2010, 02:38 PM
LsxCody's Avatar
im thinking like you, my exhaust runs from 3 dp into a couple more feet of 3in pipe into 4 in,with a 4in diesel muffler but i want a dual setup
Old 02-05-2010, 03:34 PM
waterdog's Avatar
single 3 or dual 2.5 can support about 500 crank hp.
Old 02-05-2010, 03:44 PM
Baltimore Whore
Mangled03gmc's Avatar
I don't think you can out grow a single exhaust if it is merged into a single pipe correct, using big enough pipe..I have 3 inch off my headers into a merge then into a single 4 inch.. It will def help with the merge alone, vs what you have now.. I hacked up a LPP Y pipe to work for me
Old 02-05-2010, 03:49 PM
Resident Retard
BlackGMC's Avatar
^^^^^^^^^^ that is badass!!!! Nice, simple, clean install!
Old 02-05-2010, 03:52 PM
Baltimore Whore
Thanks Corey, best of all I don't have to drop the pipes to get into my trans if i have to
Quick Reply: at what point do you outgrow single exhaust?
