What rpm stall are you guys running?
Old 08-22-2006, 11:02 PM
2000 SILVERADO's Avatar
Default What rpm stall are you guys running?
I was thinking about getting a 3200 stall, but I'm not sure if I might want to go even bigger than that. I know yank makes a 3400 stall for the f-body, but can I get one for my truck? And for those of you that have a 3200 stall, how much of a difference did it make (0-60, 1/4, SOTP)?
Old 08-23-2006, 12:25 AM
Jeff Alexander's Avatar
i have a tr220 and a 2600 converter for me its works but that cam would better match up to a 3000 stall IMO
Old 08-23-2006, 01:28 AM
dc96819's Avatar
2600 pro troque
Old 08-23-2006, 03:24 AM
BigRed53's Avatar
IMO bud, i would go with the 3000 stall, ur truck isnt heavily mod'd, but it all depends on what ur plans with it in the future are as well, but 3000 has worked well for alot of users, and its recommended for trucks like ours. so thats what i would go with, and is already in my plans.
jared
Old 08-23-2006, 09:19 AM
graysilv's Avatar
3000 tci
Old 08-23-2006, 09:21 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
Your stall speed should match your cam! No more or you are wasting usable power, no less or you dog out of the hole!
Old 08-23-2006, 09:24 AM
ZR1 DREAMING's Avatar
My cam requires I run a 4000 so I have a Yank SS4000 to compliment it's power band.
Old 08-23-2006, 09:32 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
3900 Fuddle here but like said before it all depends on your usage and what cam you are going to run
Old 08-23-2006, 09:47 AM
Old 08-23-2006, 10:03 AM
5 year bitches!
Quik's Avatar
3500 9.5 5 clutch pak PI vigi for the fbody
behind my truck it stalls to 3800
i seen 4k stalls behind stock motor fbodys and they rule for 60' and ET. i dont recomend them tho but if you want hard launches there you go
but yes you should match a stall to rpm range of cam
Quick Reply: What rpm stall are you guys running?
