What is this sensor?
Originally Posted by thunder550
Ahhh ok. Will it cause a problem with the 05 PCM if the heater is not hooked up?
The block heaters are typically in the coolant passage of the front drivers side cylinder? That picture looks like its in the oil gallery. As long as you have an alternate location to obtain an oil pressure reading then plug the location in your second picture.
Wrecker 426
09-30-2015 09:39 PM
