what should be my next mod?
#21
converter is installed!! took 3 days by myself mostly...alot of patience and alot of learning...everything came out great! stall feels awesome and now launches great...one small issue tho..i did notice that its only stalling to about 2800-2900 but its a 3200 stall..i checked the oil yesterday after a couple of laps driving with the stall and oil level semmed fine...after today i checked it and its about half a quarter inch under the hashmarks so i gotta add more oil...my question is will the added oil get the stall to go up to 3200? thats the only thing that kind of dissapointed me a bit...another thing is that it will still not break the tires loose..it really wants to but they still hold on..im running nitto 420s are these tires pretty sticky? i know with my stock 17s it should do the trick..it stalled on me a couple of times but im still waiting on my retune from black bear...stall feels great tho from a launch and deffenetly funner to play with at low speeds..although i do feel that i will notice a drop in my MPGs
#22
The retune should help. He will be able to add more timing down low. Won't be night and day though.
I'd like to see a video of it in action. Are you referring to brake stall or flash speed? See what it flashes to when you mash the throttle from a stop. Thats a more true indication.
And congrats on getting this thing in!! Great work. It's no small task and I'm sure you feel great about it.
#23
#24
A lot of it has to do with the torque you're making too. It could be a lot due to your elevation hurting power levels.
The FTI I run in my DD is true to its stall speed of 3000 or a tad more but thats a 6.0 with L92 heads and an LS6 cam.
Let's wait and see if anything changes with a tune. I don't really expect it to but you never know. The stock tunes are set up to pull timing when they see that much converter slip to keep it from hurting anything.
#25
that makes sense..thanks! we will see how it responds with the retune...on the plus side i beat a silverado ss the other day from a 30 roll..not the fastest tahoe but hey if my tahoe can beat a silverado ss now im pretty satisfied with the power its making
GM1697
09-09-2015 01:52 PM
