What single spring for .580 lift is everyone using these days?
I am looking for a set of springs and just wondering what everyone is using these days... The cam i am looking at has a .581 lift. I know the 981s got a bad rep for the broken ones that sprang up, so I don't want those. I want a single spring that uses factory retainers and keepers...
Thanks in advance.
Thanks in advance.
Im going to be using the PAC 1218 (already bought them) for my tsp 220 with .581 lift they are very good springs and good alternative to the comp 918's even though the newer revised 918's are rated to .625.
I also didn't want to take a chance on the 918's.
Pac 1218 / 1518 are the way to go imo.
I have herd that the 1218's are good up to .610 lift but that is what I saw a few users post on different forums.
Has anyone used these springs from SDPC?
http://sdparts.com/details/pac-racing/pac1218
Beehive LS1 Springs, 0.600 in.Lift, Set of 16
$122.95
Part Number:
1218
Brand:
Pac Racing
SKU: PAC1218
Price: $122.95
High Performance stock style replacement valve spring. Can use stock LS locks and retainers, seat and seal.
Rated by PAC to handle up to .600 lift.
OD: 1.290
Max coil bind: 1.140
Installed Height: 1.800
Max Lift .600
Load @ 1.800 130lbs
Load @ 1.200 318lbs
Spring rate: 313.3 lb/in
Weight: 62 grams
Frequency: 29277 CPM
$122.95
Part Number:
1218
Brand:
Pac Racing
SKU: PAC1218
Price: $122.95
OD: 1.290
Max Lift .600
Load @ 1.800 130lbs
Load @ 1.200 318lbs
Weight: 62 grams
$122.95
Part Number:
1218
Brand:
Pac Racing
SKU: PAC1218
Price: $122.95
OD: 1.290
Max Lift .600
Load @ 1.800 130lbs
Load @ 1.200 318lbs
Weight: 62 grams
$122.95
Part Number:
1218
Brand:
Pac Racing
SKU: PAC1218
Price: $122.95
OD: 1.290
Max Lift .600
Load @ 1.800 130lbs
Load @ 1.200 318lbs
Weight: 62 grams
