what size band clamps for headers?
Old 02-26-2010 | 01:16 PM
dry_kill's Avatar
Default what size band clamps for headers?
found some band clamps from jegs.com for these pacesetter headers. question is, do i need a 3" clamp or a 3 1/2" clamp? I know the pipes are 3 inches but at the joints its a little bigger, so which one do i need? thanks fellas
Old 02-26-2010 | 01:34 PM
aaronmc's Avatar
3" is what I used on my LPP's with 3" collectors and slip fits.
Old 02-26-2010 | 01:54 PM
nickleahy23's Avatar
so im guessing these band clamps are what you can use instead of welding the y pipe and such together?
Old 02-26-2010 | 02:06 PM
aaronmc's Avatar
Well you wouldn't weld the Y pipe to the headers you'd use one of the various clamps to make them seal properly like v bands, band clamps, and what most headers and Y's come with those shitty horseshoe looking clamps.
Old 02-26-2010 | 04:43 PM
zachm89's Avatar
if its a slip fit y-pipe youre going to want lap-joint band clamps. they have a little step in them, one for the larger side of the pipe and the other for the smaller.
Old 02-26-2010 | 04:52 PM
dry_kill's Avatar
yes. these are the ones ive found
3"
http://www.jegs.com/i/JEGS/555/30733/10002/-1
3.5"
http://www.jegs.com/i/JEGS/555/30734/10002/-1
Old 02-26-2010 | 05:22 PM
aaronmc's Avatar
If the collector is 3" you want the 3" band clamps.
Old 02-26-2010 | 07:50 PM
budhayes3's Avatar
PT's Slowest Truck
The Y-pipe on my StainlessWorks set up doesn't use the lap-joint style and it's sealed perfectly
Stainless Works
04-10-2016 04:34 PM
Stainless Works
13
11-05-2015 03:31 PM
maxspeed05V
08-12-2015 06:29 PM
FlowmasterMufflers
07-30-2015 05:03 PM
jrplz
07-09-2015 12:07 AM
Quick Reply: what size band clamps for headers?
