What size pushrods????????
I have the 3/8 Crane LS1 Gold Rockers in 1.85 I want to install. Will I have to change out the pushrods? Any one have any idea what studs and guide plates to use? Springs will be coming shortly and need to get these ordered....Thanks...JohnB
In all honesty, I wouldn't change out the rocker arms for your application. Get you a cam, 918 springs, and some hardened chromemoly 7.4" pushrods and you'll be good to go...
The rocker kit doesn't come with studs? I think I would contact Crane. Then when recieved and installed do the felt pen test. Mark your valve tops with felt then roll the engine over and see that contact is centered. This contact is varied by pushrod length and with such a high ratio, you'll want to be sure the rocker tip doesn't slip off the valve! Someone jump in if I'm full of $%&
jtphelps289
09-29-2015 12:00 PM
Closer_2001
09-24-2015 09:15 PM
