What size single exhaust are you running, 600 rwhp and up?
#25
Sounds like Magnaflow might be worth looking into.
#26
for my 4" muffler i used the really long one they have. it bearly fit up in there but it was worth it for interstate use.
#27
GFYS and STFU
I don't have a vid of my exhaust now but I did a e-cut-out right after the turbo and when closed I bought and ran the exhaust through a stock muffler.
It sounds close to if not completely stock when closed and when opened it sounds like a alcohol boat. If your really gonna go with full exhaust and no cut-out then do a single (dual has more internal surface area to overcome, I know it sounds stupid but it hurts exhaust flow) 4-inch. At low RPM's it will probably rumble a little too much but at WOT it will breath effortlessly.
btw is this how your gonna widen the distance from Kyle? What's he running?
#28
He's got a home made exhaust kit and a Warlock muffler with a built-in cut out. I don't want to mess with a cut out, just another moving piece to potentially break, and I'm sick of adding electrical **** to my truck. I want it there and ready to go all the time. It's gonna get at least a 4" single all the way back(already decided against duals). I'm tossing around the idea of doing a 4" downpipe then expanding to a 5" exhaust too. I wouldn't mind running a giant muffler to quiet things down either.
Last time he ran here in town he put down a 12.79 ET at something like 105 mph. I ran a 12.74, so he was right there with me. That was when I was on 8 psi though. I'm gonna try to run it at 12 and see what happens this weekend.
#29
GFYS and STFU
I don't have a video of it but I will next time I go back out but the number one force to overcome for ship in the ocean is Hull drag. If you ever go out on a positive displacement vessel and look at the hull at the waterline you'll see 4 or 5 layers of sheering of the water. Basically put if the ship is doing 20 knot you'll have several layers of water maybe 3inches wide going different speeds from 20kt at the hull, to 16kt, 12kt, 8kt, 4kt until 0 where the water isn't being dragged by the ship. It takes alot of force to sheer any medium weather it be a fluid or a gas such as your exhaust (granted it's less being it's a gas). The less surface area in your exhaust with the most volume will net you the best flowing exhaust.
