What would I run??? Turbo... Magnacharger
Well....the rear mount turbo does have it's benefits, but if you're looking for something that's relatively simple to install, with tons of low end torque, then Magnuson is the way to go. Two things I don't like about the rear mount turbo: one is the way the intake tube has to wind around the front body mount, and two, using the engine's oil supply just give me the heebe-jeebies! I just don't like tapping into the oiling system. If I were going to do it (and I almost went that way), I'd run a separate oil line from a tank in the bed. But....I ended up going with the Radix, and I'm glad I did!
Mossyoakglock
07-17-2015 08:30 AM
