What is your oil pressure with your LS6 Oil Pump?
PT's Slowest Truck
I remember someone saying something about the pump needing to be shimmed or something I didnt do that I just tightened up the pupm is that where I screwed up at cause my oil pressure gauge doesnt peg out at WOT?
Originally Posted by 99Silver5.3
Not the kind of shimming Im talking about. Im referring to shimming the pressure relief valve of the pump. Thats how you get a high pressure pump.
My ported LS6 pump makes about the same pressure as the stock one. I don't think that there is fundamentally really any difference between them. However, shimming that relief valve would probably work to increase peak pressure.
How do you do that? I dont know what the pressure relief valve is. I may be pulling the motor shortly to rebuild it since its burning oil now. Hopefully its just a messed up valve guide seal.
Banned
1 Post
Why Do You'll Want So Much Iol Pressure 30 To 40 All The Time Is Good To Much Is Not Good Either It Will Wash Out The Bearings Faster. That Is Not Good Either.so In The Middle Is Good. I Go Off Of Idle It Should Be Around 30 To 35, As Ling As It Goes Up And Not Down When I Give It Gas It Is Good.
