whats this?
Old 01-31-2007, 09:12 PM
SSSBLKOUT's Avatar
Default whats this?
Is this an LQ4 or an LQ9?
What did the LQ9 come in, and the same question for the LQ4?
How, visually can you tell them apart?
What are the specs (differences) between the two motors?
http://www.sdpc2000.com/catalog/120/...ate-Engine.htm
Old 01-31-2007, 09:15 PM
FormerVendor
Derek @ EDO's Avatar
that would be an LQ9 cant tell externally
beefier rods - different pistons
BTW you can get them alot cheaper than that from ebay and salvage yards!
Old 01-31-2007, 09:21 PM
SSSBLKOUT's Avatar
Rea - he-he-he-heaaaly
Old 01-31-2007, 09:26 PM
Mr. Obvious
nightrunner's Avatar
also note if you get an 05-newer version the lq4 and lq9 get the same rods(LS2) and both get LS2 timing chain so basically the only difference then would be the lq9 would be a slightly higher compression engine
Old 01-31-2007, 09:33 PM
SSSBLKOUT's Avatar
I would be putting it into an 02 5.3L engine bay, are there any special tricks. I wouldn't think so, just a good tune on the trucks factory computer and harness, right? All the sensors should be somewhat in the same spot, i think?
It seems like there should be more problems, but I can't think of any.
Old 01-31-2007, 09:36 PM
FormerVendor
nope, just bolts in. All you need is a shortblock. The intake manifold and all acc. will swap over. All you will need is an updated tune.
Old 01-31-2007, 09:50 PM
SnakeOiler's Avatar
.... and eventually a new transmission
Old 01-31-2007, 10:11 PM
southern_chevy's Avatar
the trans may come sooner than you think. Just depends on how you drive
