whats the difference between the manifolds
suchs as in brand name and for example the weiand intake manifold for ls1 type engines and the fast etc etc
they claim to add hp over our stock ones
but yea i would want to run the ls6 manifold but u gotta change a lot of shet so thats why i was planning on the fast or weiand type manifold...
Mr. Obvious
not sure about price, i guess it depends on where you get.
weiand - aluminum - a large heat soak, very bad, very minimal gains
FAST -expensive but what most guys run if you dont stay with gm
most truck guys go to a LS6 if they swap manifolds. i would swap heads before intake manifold
fast is composite and is a two piece to were you can have a 78mm tb or a 90mm tb..the bbk can accept a 85mm tb..then the professional products accepts to a 90+mm intake..for performance differences look on ls1tech and do a search..
im not sayin that heat soak doesnt happen on aluminum intakes, but id like to see a dyno run with the motor fairly cool and then another dyno pull with the intake hot
maybe i should be the first to try one of these babys and tell u the results ... this was gonna be one of my next mods.... i was going to by the fast intake last week but my rear went out and i just go my truck back...
