Whats next?
Old 02-18-2007 | 04:40 PM
  #31
v8
17,16,15,14,13,12,11 Drvr
Its in the tune, your throttle body is not opening 100% at first and its shifting out way too early, look at first video and listen, you down shift then upshift within a second, and the other truck stays in the down shift gear longer, both trucks are setup pretty close in mods minus the cam and its not a very big cam at all, so with the tune messed up he will walk you every time.
Old 02-18-2007 | 06:56 PM
  #32
Phantom's Avatar
11 Second Club
tyler chime in here
Old 02-18-2007 | 07:05 PM
  #33
Phantom's Avatar
11 Second Club
Originally Posted by Rhino79
That should not happen, with a cam and no stall you should walk a bolt-on truck from any roll.....what are you shifting at, whats the AFR, how much timing you running? Something's definetly not right somewhere, I would think shifts need to be around 6300 or maybe even up to 6400, especially with no converter to help your shift extension. A stall will definetly help but I would not get the TT3000, its the same size physically as the stock unit, and its based on the TT2600, and you can not restall it if you wanted to. Go with a 3200-3400, especially with that heavy truck. You have a good list of mods, just have to get the kinks worked out.
It shifts at 6000...It stopped gaining hp at 5300 rpm (started pulling timing for some reason) when he tuned it so he went ahead and had it shift at 6000. I can't remember what the afr is...12.x maybe i can't remember. Hopefully dirt_track_racer_81 will chime in here in a second....As you guys can tell I'm really bummed out...
I got the TT3000 for the stock drivability as i drive my truck 60 miles a day and need as close to stock drivability as possible. any ideas on why it starts pulling timing around 5300? Help us out here guys
Old 02-18-2007 | 07:16 PM
  #34
bigbadwolf54's Avatar
13 Second Truck Club
From the sounds of things and by the videos I'd have Tyler double check that tune. My truck runs about 26 degrees around 6000rpm@WOT. But theres a few things that could cause it to pull timing, maybe he just overlooked something ...?
Old 02-18-2007 | 07:17 PM
  #35
I run mine to 6300 1-2 and 2-3 and dont have a cam. You need those shift points up around 6400-6500. Figure out why timing is dropping and up the shift points and I bet you hand him his ***. What timing are you running now?
Old 02-18-2007 | 07:20 PM
  #36
Phantom's Avatar
11 Second Club
we just didn't figure there was any reason to take it much high since the power started droppin off like that...i'm around 26* timing i believe
Old 02-18-2007 | 07:29 PM
  #37
RoosterMcCandles's Avatar
Mine runs up to about 6100 and it pulls decent through the band...
Old 02-18-2007 | 07:31 PM
  #38
nightrunner's Avatar
Mr. Obvious
there's got to be something wrong in the tune or thiems has a factory freak
Old 02-18-2007 | 07:34 PM
  #39
Factory freak FTW!!
Old 02-18-2007 | 07:37 PM
  #40
Phantom's Avatar
11 Second Club
the only thing i can see being wrong is the shift points
