whats parts are interchangable from a 5.3 to ls1/2/3??
Old 01-31-2009 | 06:19 PM
Taubr Unit's Avatar
Default whats parts are interchangable from a 5.3 to ls1/2/3??
Figure you guys here would know more about it then ls1tech...
Im doing a 5.3 turbo swap in my car and need to know what parts i can use from a ls1. As in intake, cam, oil pump etc. Can i buy any ls1 part and it bolts up? Anyone know a lot of tech. bout these 5.3 motors?
Old 01-31-2009 | 06:34 PM
95 bright teal's Avatar
Pretty much everything will bolt up, I think there are some sensors that wont, but intake, heads,cam, lifters, springs, rockers, accesories will bolt up.
Old 06-08-2009 | 02:02 AM
cutlass_455's Avatar
Is this true for a 4.8L as well?? I have a 4.8 that I am transplanting into a 87 Olds and would like to swap due to hood clearance. I am aware of having to swap over the accessory drive. I just want to make sure the LS1 intake will match my 2001 4.8L heads.
Old 06-08-2009 | 02:08 AM
SincalT/A's Avatar
It is true almost everything interchanges between 4.8/5.3/5.7/6.0.
The 6.2 ls3 is not quiet as interchangable.
Old 06-08-2009 | 09:42 AM
budhayes3's Avatar
PT's Slowest Truck
Be aware that the LS1 intake will not be a direct swap with the truck accessories, as there will be clearance issues. The truck intake has been proven to perform better than the LS1 intake anyway...
Old 06-08-2009 | 12:14 PM
jnewnam88's Avatar
What is a good head, cam combo for a stock 03 suburban with the 5.3. Im not trying to do it for towing or anything just to beef upp the big body.
Old 06-08-2009 | 02:24 PM
mcfarlnd's Avatar
Un-Registered User
start your own thread man. also, try using the search feature. as for a combo there is tons of info for the 5.3 on here you just have to look.
Old 06-08-2009 | 06:27 PM
Ok, thanks, I just wanted to make sure that the intake ports will line up and stuff. I know that I will have to change the accessory drive stuff, and Ive already got a bunch of the stuff for that conversion. Like I said, I want to switch to the LS1 intake due to hood clearance issues in my conversion project. And also, the Fbody accessories clear my cars frame better anyways. Thanks.
Raggedz71
07-29-2016 10:20 AM
TimDave217
08-24-2015 04:38 PM
mrhino
08-07-2015 10:01 AM
OLD BULL
08-01-2015 05:00 PM
walledition
07-29-2015 08:54 PM
Quick Reply: whats parts are interchangable from a 5.3 to ls1/2/3??
