Whats Wrong?
Old 03-22-2005, 03:45 PM
gonzo 6.2's Avatar
bank 1 is drivers side,maybe a wire got pulled when the 02s were disconnected
Old 03-23-2005, 08:51 AM
Ok I Had Someone Clear The Codes Yesterday But When I Cranked My Truck Up This Morning It Was Back On. There Were 4 Codes All Had To Do With Bank One Sensor One. That Should Be The One On The Drivers Side Before The Cat Right? I Already Switched It Out With Another One And That Didnt Work. The Codes Said Something About It Not Being Active And Something About The Heater Circuit. What Do I Do Know?
Old 03-23-2005, 08:55 AM
01Blackerado's Avatar
Let me ask you something...you didnt happen to do anything with the injectors did you??? Like clean em or take them out and put them back in, anything??!!
Old 03-23-2005, 09:32 AM
nope just headers and exhaust! this is starting to **** me off!!!
Old 03-23-2005, 10:11 AM
silent1's Avatar
Your ASM's are going to need to get ceramic coating. Your o2 heater can't get your o2 hot enough to work properly. The coating will keep the exhaust heat inside which will allow your o2 sensors to warm up properly. Do a search and you'll see that everyone with ASM's went through this.
Old 03-23-2005, 10:20 AM
they already come coated inside and out.
Old 03-23-2005, 10:37 AM
well damn looks like your running lean somewhere sorry to state the obvious... Im all out on this one unless the exhaust didnt seat and seal correctly then i dont know what else.
Old 03-23-2005, 10:41 AM
well when i took the o2 sensors out they were both really black so wouldnt that mean im running rich. and if so what would make it do that?
Old 03-23-2005, 02:14 PM
when the front sensors go bad, the computer goes into limp mode and runs really rich to keep from blowing up the engine.
Old 03-23-2005, 02:33 PM
WELL IVE ALREADY CHANGED THE O2 SENSOR OUT THAT WAS SHOWING TO BE BAD AND IT DIDNT WORK. I THINK I AM GOING TO SWITCH IT WITH THE ONE ON THE PASSENGER SIDE AND SEE IF IT THROWS A DIFFERENT CODE OR MAYBE THAT WILL CLEAR IT UP. AWE WHO THE HELL KNOWS!!!!!!!!
Quick Reply: Whats Wrong?
