Where to start tuning ?
Hey guys it's been a long time since I've messed with edit could someone give me a little run down on what I need to do. I have a 4000 stall and I know I need to change some stuff for that and for the bigger motor so can ya'll help ?
10 Second Truck Club
For starters:
-reset rpm limiter
-reset mph limiter
-reset shift points
-adjust IFR to give -6 to -8 Ltrims
-turn "cot" off
-adjust power enrichment versus rpm for a/f ratio 12.75 to 13 to 1 @ wot
-turn torque management off
-raise shift pressure
-adjust high octane timing table to 26-28 degrees @ wot above 3000 rpm
-copy high octane table to low octane table
maybe some more will chime in here with other pointers, there are a lot more!
-reset rpm limiter
-reset mph limiter
-reset shift points
-turn "cot" off
Originally Posted by redaddiction
thanks alot I wll get on that tonight and see how it goes. how should I work around the huge stall ?
Mossyoakglock
07-17-2015 08:30 AM
