Whipple air temps!
Re: Whipple air temps!
Radix superchargers use a bypass valve that works off engine vacuum so you only see boost under hard accelaration I'm sure that keeps the intake temps at a level the intercooler can manage,instead of constantly producing boost and the heat that comes with it.
I hadn't thought about the bypass being responsible for heating the air under non boost conditions. I "tweaked" on that 2 years ago and now it makes 5 psi by 40% throttle. I am planning on going to the local 1/8th mile this coming Friday and shooting a dry shot just to see.
I had an issue with the Whipple on my 8.1. It blowing off boost at WOT. The truck would see 7.5# and then go down to 3.8, 4.2 and then hang around 4.5#. I ended up pulling the line that runs to the bypass and plugging the end from the supercharger. Turned into a different truck after that. It now makes a solid 7.5# all of the time. Whipple tried to play with the tuning for their computer but that didn't work.
single digit dreamer
a blow off valve and a bypass valve are substantialy diferent. with a blow off valve the boost has been made and gets bled off but with the bypass the boost is never made. one of the reasons they do this is so the blower uses almost no hp when not under boost, it is a great system.
what tybrine is talking about is whipples atempt to use that bypass valve as a saftey device or maybe even a tuning device. the whipple computer watches the 02's and if it sees a lean condition it will open the bypass and relieve some boost. seems like another good idea to me. mine opened a couple of times, once when my fuel pump was maxed out and another time with a bad 02 sensor. i wouldn't have been alereted to either one of these problems nearly as quickly without that whipple light flashing in my face.
i am not doubting anyones IAT but just to be sure here how did you measure them? prety sure with the radix you would have to insert a probe or somehow move the AIT sensor. i guess the ATI set up is a blow thru on the MAF? so it is acurate?
one last thing, my AIT temps went way high on my truck even though the MAF and AIT sensor was in the stock place(before the blower). i would see as much as 100deg above ambiant once i got on it and i am 100% sure it was a false reading, did i just have a problem or is there some reason for the sensor to read way high when the air really starts to flow?
airflow across the sensor cause the increase in temp reading???
Adkoonerstrator
Does the Whipple computer hook into the MAF wires at all? Could this be an attempt by whipple to fool the computer about the temp to lower timing?
Tom-I plugged that same hose early on when I noticed boost going away at the 2-3 shift. I finally coaxed it out of Whipple that it was there to save the tranny. Sure enough a few weeks after plugging it off the tranny started slipping.
The Whipple computer does cause false IAT readings. When I still had mine sometimes it would show -40, sometimes 100+ over ambient. It also messed with the engine coolant temp. My truck didn't start coming around til I got rid of all that crap!
