Whipple single belt electric solinoid mod please help
I searched and found that big thread from long ago about how to disconnect the electric emergency bypass on a whipple without touching the vaccum bypass so that it would still function under cruise. However, that thread seemed to be directed twards people with the two belt whipple set up which is alittle different and was pretty confusing with no clear cut answer. My whipple is going on this weekend, can somebody please tell me what vaccum line to cut or what to wire to what ofr my single belt system? (i do not have any whipple electronics)
Thanks,
Nate
Thanks,
Nate
there are two lines on the electric part, do i cut and cap the part comming from the blower to the solinoid, or the line going from the solinoid to the vaccum actuator? or does it not matter which one it is?
Nate
Nate
That long thread you found had nothing to do with the 2 belt set up. I have the 2 belt setup and there is nothing electronic about the bypass; it's all mechanical. Listen to ranwalk. He knows......and dump their computer setup. You'll be happier in the long run.
00z71sierra
00z71sierra
GXPJAY
02-13-2022 08:15 AM
RoidedSS
08-11-2015 11:51 AM
