Whipple Supercharger problem...
Old 12-18-2003 | 07:25 AM
  #21
00z71sierra's Avatar
I had a grinding noise as well when I turned the pulley by hand and it turned out I needed a replacement s/c. Hope that is not what you need. Of course the replacement s/c made grinding noises as well and I was told it's normal; deal with it. The second replacement they sent me isn't as noisy as the first so I know something wasn't right with it.
I think if you disconnect the whole computer setup (meaning unsplice from the PCM harness) then you might be able to get away with it. If you only had a connector unplugged to the computer box but it was still hard wired in then it was probably picking up signals that some things were disconnected. Does that make sense?
Old 11-25-2018 | 07:22 PM
  #22
DOZEREMC's Avatar
Registered User
Default I have the same set up 2002 5.3 with side mount whipple.
I had this motor put in when mine blew last year. the guys who did it screwed me and 5 months later I got it back. it's suppose to be bored out 30 over. molly pistons with 12.5/1 compression. he put stock cam back in despite repeated times of me telling him not to . and did a half *** job to say the least. now im no mechanic but Im inclined. I just don't know much about sc. I have check engine light on code reader says it's egr low voltage as far as i can tell there isn't one. it wants to run but it bogs out with more than 1/3 throttle. if anyone has tips or suggestions potential problems and solutions to help me out would be greatly appreciated thanks in advance.
Old 11-25-2018 | 07:32 PM
  #23
03sierraslt's Avatar
This thread is 15 years old, what are you trying to say? You have a 12.5-1 engine with a stock cam and a supercharger?
esoteric_ast (11-03-2019)
Old 11-25-2018 | 07:58 PM
  #24
DOZEREMC's Avatar
Registered User
yes that's what i'm saying I need help tips issue solutions anything that points me in the right direction
Old 11-25-2018 | 08:25 PM
  #25
Why are you running a street motor at 12.5-1??? Let alone with a blower. That’s a horrible idea and will ultimately end up with a blown motor.
Old 11-25-2018 | 08:47 PM
  #26
DOZEREMC's Avatar
Registered User
I apologize for my ignorance I'm going off what i was told. I really don't know what been done to my motor. or even if he did anything to it. it runs but bogs out with les then half throttle egr is throwing p0405 code that's what I do know.i can't find an egr valve.
Old 11-25-2018 | 08:48 PM
  #27
madmann26's Avatar
*again
there, fixed.
Old 11-25-2018 | 08:52 PM
  #28
Are you saying you have a motor from Ryan23silverado???
Old 11-27-2018 | 05:37 PM
  #29
terravast4's Avatar
Holy ****. you need more compression for that supercharger....
Old 11-27-2018 | 11:48 PM
  #30
_zebra's Avatar
makes children cry
a cam with some healthy overlap should at least lower your dynamic compression ratio enough to manage the tune.
