whipple tuning questions, ryan, parish, everyone
I am confused as to what you guys are seeing in respect to O2 readouts. I have the whipple computer hooked up and never see any wierd spikes or low flatline O2 readouts. If I unplug the comp. the O2s stay the same (a little higher simply b/c of less boost) But nothing is really adversely changed in O2s. So, is there really a difference in whipple tunning in their piggyback computers??? Well, aparently there may be. However, it is nothing that could justify whipple's price tag.
I think there are underlying problems that are causing this to happen, namely fuel. I would not begin rewiring whipple-pcm connections, unless you understand all of the electronics, then by all means splice away I would wait to get new injectors, set the new IFR (i can help you) and I bet watch your O2s come into line. If they don't, well then I would think you have reached the point of ditching the w/comp. tunning the pcm with edit and rewiring the bypass solenoid with a relay to activate the solenoid at a certain tps%.
Originally Posted by etc
i assume by the lack of response that the maf can handle the actual airflow and the map can handle the postive manifold pressure.
Without the w/comp hooked up .79-.85 is still really lean. This might be off the wall at this point, but you are sure the O2s are good?
i don't think it's off the wall, i think it's the headers and intake and exhaust. i don't think they're bad the numbers are consistant and the voltage varies [up and down frequently on graph]. also am not throwing codes until its floored with the w/comp hooked up, code is only low voltage not slow response. i would think the pcm would compensate but maybe not. i should probably have talked to you sooner and adjusted the pe tables but i'm getting the larger inj's so i'll deal with it then. if your interested you can recap the procedure for me. i have the pm but maybe someone else would like to see the info. i believe you said change # in ifr, then ,what to adjust for 0 l-trims? [tables and which way for lean or rich].if i end up bypassing the whipple do i need to adjust high maf fail, and should i have adjusted anything pertaining to air volume already. matter of fact since you have messed with this , could you touch on all the tables in edit you had to mess with [ minus anything regarding the intercooler for now]. i know it's alot of info but i'm sure it would help me and alot of other rookies out. thanks, eric
Originally Posted by myself for the third time
Okay here is what I said in another post about using L-trims to tune for Injector Flow Rate.
"YES hohl seems to know what he is talking about. When you mod an engine, the Volumetric Efficiency changes. The VE tables affect L-trim readouts. For example, your l-trims could be perfect while in the VE cells of 5 and 21, but when you are in cell 7, it could have some wierd readout of -20 on the L-trims. What hohl was saying about the mapping out of the VE table is also right. Someone on this forum discovered which VE cells are PE (Power Enrichment) cells and which ones are at cruise.
When tunning you should use your L-trims to calculate what your IFR number should be. Take a long cruise and log all of your L-trim readout. Average them and multiply it as a percentage to your existing IFR numbers. For example: if your averages for Bank1 come out to +3.2 and averages for Bank2 come out to +3.0 -->avg. those = +3.1, so to richen up the mixture, multiply the IFR table by 96.9% (this will yield a smaller number in the IFR table than when you started) The lower the number in the IFR cells, the richer the engine will run.
If you have messed up VE cell values, then it will affect the L-trim readouts, affecting the IFR number, which will mess with engine performance. Use the stock settings on the VE tables! Even with my pretty big mods, only one cell is giving me troubles in the VE. I see this when I let off the throttle after giving it lots of gas, but not enough to jump into PE. The L-trims when I am in that VE cell go to something like +20. I disregard any L-trim readings in that VE cell if I am tuning for IFR."
Ryan
thanks ryan, so you're saying to tune for the larger inj's you only adjust the ifr ? do you know why smaller #'s in the ifr table result in richer mixture ?. the only thing that makes sense to me is, you're telling the pcm it has smaller inj's than you really have and it compensates by doing what ? changing the pulse width ?. when does pe come into play ? at certain tp ? or is it triggered by o2 readings. e-mailed whipple regarding the computer, they havn't responded, actually will be suprised if they do. their customer service leaves much to be desired, seems like " we already cashed the check, good luck with that, and no we are not willing or able to discuss technical matters ". doesn't seem like a good way to get repeat business. not mine anyway. would really be lost without everyone here's help. anything to beware of when installing the new inj's ?. e
got the new inj's today. any tip's on the install, things to be careful of ?. then what ? ryan, you said change #'s in ifr table to 5.30, the sz speed site said they are 43 lb inj's, tex said they flow 42 at our fuel pressure, is that # close enough ?. anything else before i start it ? then log l-trims and adjust the ifr #'s up or down respectively ? like to get this going, please chime in if i need to know anything else. should i bypass the whipple computer on the first run ? or should i be alright ? if everything looks ok at partial throttle should i do a short full throttle run ? talk to me guys, thanks e
No real tips that I have. It is a pretty straightfoward swap. Oh maybe one thing, when you put in the new injectors wipe a little vasoline around the o-rings. This helps them seat more easily with little chance of the o-ring slipping out of the groove on the injector. Don't use globs of the stuff -just enough to get like a film of vasoline on it.
A 42psi (at our pressure) injector should be perfect. Unplug those auxilary injectors after you put in that 5.30 ifr number in all of the ifr cells in edit. Next, go out log l-trims for at least 10-15 miles of Normal driving -don't go into PE by giving more than 40% throttle. ***Take that file you just logged and while still having that file open in AutoTap click on File -> export to a coma deliniated file (sp?) I am pretty sure this function is under the File menu. if not just look for it on one of the top toolbar commands. This will put your entire log into Excel (download Excel off the net if you don't have it) Next, highlight one of the l-trim columns and select the entire column by holding down the mouse and scrolling down to the end of your log of l-trims in that column. With it still being highlighted, click on the "sum" symbol in Excel (a symbol that looks a black E at the top icons) This will add all of those l-trims logged in your run for that bank of the engine and put it into a new cell either at the top of the entire column of logs or beneith it. Divide that number by how many total readings you logged. i.e. you are averaging. Next do that to the other bank of l-trims. Average your averages and use that number as a percent to change your IFR table to.
Follow how I explained it with examples befor in a previous post if this is not super clear. I pretty much just wanted to let you know how to export a file and let Excel do all of the math for you.
Do a second log and confirm that your l-trims are more in check (somewhere between +4 to -3) You may want to export the file again and just average everything again. Are you around zero for your overall average? Good you are set.
I wouldn't bypass the Whipple comp on the first wide open throttle run. If anything you should be rich. Now I hope the O2 readouts are between .89-.93
Let us know
Let us know
