Who is Justin????
Who is Justin????
http://ststurbo.com/gm_truck_suv_sound_and_video
Justin has a 4x4 ext.cab with a 5.3......STS and 13lbs of boost!!!!!
Good god that thing rolls out.......anybody know who it is?
I'm hoping to see more power now with the bigger turbo and 6.0L heads and head studs. My compression should be right around 8.5:1 or maybe a tad higher so I can safely run 13-15psi I would think unless something else decides to let go. If money permits I'll work on an intercooler setup for this system on our trucks. If I do then it should be a simple matter to give specs or you can order directly form the guy I get mine from
jscherbs
03-24-2017 07:20 PM
jscherbs
09-30-2015 07:54 AM
