Who Makes The Best Differential?
Old 04-25-2004 | 12:41 PM
one03sierra's Avatar
Formerly one92rs
Talking
well i have talked to all the rear end guru's around and they all say that they are putting in the royal purple or mobil one in them.
Old 04-25-2004 | 01:12 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
If you have an Eaton, read the instructions that come with it. It specifically says to use GM minerals.
Old 04-25-2004 | 01:33 PM
Formerly one92rs
yes you are coorect. but all the builders here including century,arabie racing and pyle bros who do it day in and day out have been using synthetics in all there builds. they put it in theirs also. there are several people here that are using synths in theres with no probs whatsoever.
Old 04-25-2004 | 05:07 PM
Hit Man X's Avatar
Eaton is awesome. It's rebuildable in the vehicle where the Auburn must be removed and sent in due to it's conical frictions. Eaton uses carbon fiber clutches as well as 400lbs preload springs...upgradable to 800lbs of preload! It's what I have in my F150.
The traction of a G80 compared to the Eaton is day and night. It's still smooth and all but there's no bullshitting when it grabs.
Old 04-25-2004 | 11:05 PM
03-25HD's Avatar
Detroit! Check with all the serious off-road or drag guys. Most of them use Detroit, cuz they just don't break.
Old 04-25-2004 | 11:19 PM
454SuperSport's Avatar
i vote for the eaton, haven't had a problem with mine.
Old 04-26-2004 | 10:11 AM
BigKID's Avatar
I replaced my broken G80 with the Eaton unit and couldnt be happier.
One comment on the Detroit though... You guy are correct on it's undestructability but it has very poor street manners. I would not recomend one for your daily driver unless you are poring a large amount of horsepower on it.
Old 04-26-2004 | 12:07 PM
yellowls1truck's Avatar
I guess Eaton looks like the way to go. Does anybody know whos got the best deal on it? How about a part #. If i was just changing my diff out and keeping the stock gears, would i have to "reset" my ring and pinion clearances? Or will it all just bolt up?
Old 04-26-2004 | 12:51 PM
Hit Man X's Avatar
589-Gears have good deals. They are in upstate NY somewhere. I paid ~$325 for the one I have. They are on ebay too.
I'm almost certain you're gonna have to reset back lash, so if you want gears...do them now. I'd also get new axle seals and bearings while it's apart.
Lastly...while the Detroit locker may be stronger, you lose LOTS of streetability with it. An Eaton w/ 800lbs preload springs will grab hardcore too...
Gadgetized
08-21-2020 03:14 PM
Corvette454l88
09-01-2016 01:24 AM
lxcoupe
08-24-2015 08:16 PM
Martin4_8
08-13-2015 07:31 PM
Quick Reply: Who Makes The Best Differential?
