Who is running a 02 LS6 cam in there truck?
Old 08-23-2006 | 06:54 PM
onebad96T/A's Avatar
Default Who is running a 02 LS6 cam in there truck?
A friend of mine has a 02 LS6 cam and springs, he told me it would gain me 30-45 rwhp on my 06 truck.
Has anyone done the LS6 cam swap?
What power have you gained?
Old 08-23-2006 | 07:06 PM
Z284thgen's Avatar
11 Second Club
i doubt you will see that much RWHP gain will be good for about 15-20 IMO
Old 08-23-2006 | 07:13 PM
adrenalinep's Avatar
I have one it did help out alot ,This book I have said it gained 40 hp at the crank on a 5.3. If I would do it over again I would of gone with an aftermarket. It did lower my et elec fans,ls6 cam with no tuning I went from 15.3 to 14.7
Old 08-23-2006 | 07:50 PM
What about sound how lod is the cam is it noticable?
Old 08-23-2006 | 07:51 PM
i used to have one. on the 117.5 LSA its not very noticable really. IMO it will jsut make you want a bigger cam once you know what a small one feels like. a year after my LS6 went in i ended up with the one in my sig
Old 08-23-2006 | 08:03 PM
dirt track racer 81's Avatar
there are bigger and better cams out there..if your going to go through the trouble of putting a cam in, you might as make it as worth while as you can and stick in a big cam, soon2bespooled is right, right as you stick in a cam you will want one bigger and then go bigger...i put in 3 cams in one month..
Old 09-02-2006 | 12:23 AM
BlkNight02's Avatar
so an you put an ls1 or 6 cam in a 4.8 with out doing any tuning?
Old 09-05-2006 | 12:20 PM
SS_bnoon_SS's Avatar
The '02 Z06 cam is mild enough that it will run on a stock tune, but a tune will make it run even better.
Old 09-05-2006 | 01:55 PM
this is true, i ran that cam on a tuned, but not tuned for cam, kinda thing for a few months, got it tuned up for the cam, and ran it for a total of a year, then i still had the cam bug so i HAD to go bigger. IMO, dont waste your time with small cam let alone a stock sized cam of any kind, you will like it but it will only make you want bigger
stealthperf
34
02-14-2016 12:35 PM
The_W
10-28-2015 10:00 PM
black6spdz
07-16-2015 02:32 AM
Aboss
07-09-2015 11:28 AM
Sbrown06
07-09-2015 10:21 AM
Quick Reply: Who is running a 02 LS6 cam in there truck?
