Who's going under their truck today? Can you look at something for me?
Old 03-03-2010, 09:11 PM
scooter k's Avatar
It bolts to the trans. They wouldn't bolt to the body because that would transmit noise. I have only seen those on a 4L80 that uses the factory dual inlet muffler.
Old 03-03-2010, 09:24 PM
zeake's Avatar
My RCSB does not have this. It is usually on a 2500hd bolted to the transmission.
Old 03-03-2010, 09:28 PM
BadAssChevy327's Avatar
well my 4l65e SSS has it. i believe any 6.0 factory truck has it. it just holds the slip fit and bolt up one. its a smart design everything moves with each other
Old 03-03-2010, 09:37 PM
hirdlej's Avatar
Right, so since they made regular cab 6.0l trucks (2500 series) I'm sure there's a provision in the cab to bolt this hangar on, correct?
Old 03-03-2010, 09:39 PM
it bolts to the tranny. end of story. but they did make 6.0's with 5 speeds. in the 2500 hd. so i dont see a reason why it wont work.. or if not you can find one off a 5 speed one.
Old 03-03-2010, 10:16 PM
1Bear's Avatar
There are various mounts for the different transmisions that were available with the 6.0 & 8.1L engines with dual exhaust pipes. You just need to pick the correct style for the transmission and exhaust configuration you have. I believe I got the designations right, but one would be prudent to verify before ordering anything.
4L60 Mount
4L80 Mount
(RPO) MT1 C5F/C6P Mount
(RPO) MW3/C6P Mount
(RPO) ML6 Mount
(RPO) M74 Mount
Old 03-03-2010, 10:24 PM
zachm89's Avatar
it goes up over the crossmember and bolts to the side of the trans just like the image above of the 80e. i pulled mine off when i got my exhaust redone because they put other hangers on instead.
Old 03-03-2010, 10:28 PM
hirdlej's Avatar
Arrr har har!!!! I like the pics! Livesaver. I'm going to go see if there's a provision on my trans that would allow me to use the 6 speed manual bracket
Old 03-03-2010, 11:21 PM
PT's Slowest Truck
budhayes3's Avatar
Yessirreee, good job 1Bear, those pics cleared it up for sure Now I see how it goes...the pic in Joe's first post is deceiving
wrb002
08-31-2015 12:00 PM
USMCvet0311
08-13-2015 09:59 PM
black6spdz
07-16-2015 01:32 AM
Stainless Works
07-15-2015 10:26 AM
Quick Reply: Who's going under their truck today? Can you look at something for me?
