Why can't I smoke my tires?
Originally Posted by shandy294
Do you have TM removed? My 4.8 will spin a little on certain surfaces at certain temperatures but nothnig like a burnout.
its not tuned at all i just have a k&n filter cut out the bottom of the box put 4"pvc pipe inplace of the intake tube e-fan and cut my muffler of and put a 3'pipe in place of it. oh and bypassed the tb hose and descreened maf. thats all so far but i am peg leg and it sucks cause i have a bad tire spin problem if i want to get out in traffic in a hurry i have to put in 4hi. my wife said she want so new tires. there the stockers on 2200 miles on truck so far.
If you took it to a dyno they should be able to wideband it for you and you could then report back to allen and have him make some changes. Do you have access to a scanning tool?? With Edit you will still need a scanning tool. HPTuners has both. That is where my money is going..... if this laptop that I paid for 3 weeks ago ever gets here.
Originally Posted by DanaliHD
Ok, so I have the Whipple with 8lbs boost. I ditched the whipple computer, added the 43lb injectors and got a new tune from Nelsonperformance. The truck seems to go pretty good, but, I can't spin the tires. From a dead stop, it I floor it, it hesitates for a second then they spin for about 2 seconds. If I try to powerbrake it, it totally bogs out and they don't spin at all. Anyone have a guess?
Denalihd, I have the same problem with mine. Now It is not as built as yours but it is a 03 2500hd GMC with the 6.0 , 4.10 gears posi. You can try to do a breakstand and it just bogs. I also have exhaust, upd, descreened maf, Predator program. Thinking about a stall conv.
