Why is my oil everywhere but in the engine?
#71
Also, I have some good lq4 pistons if you need them with the rod hanging on them still. If you were wanting to do a quick cheap fix. You can have it all it would cost you is shipping down and shipping me your rod back.
#72
Originally Posted by 1SlowHoe
I will try to get them mic'd.
What would the shiney spots indicate?
As MJ points out it could be a send ring land busted that would be hard to see without the pistons out.
You really have a strange condition. I can see broken ring or blown headgasket affecting 1 or 2 cylinders. All 4 down in compression and nothing obvious with the head off is seriously strange IMO.
#74
Quick update:
Engine removed
2 Broken rings on 1 piston, still pulling others. (piston tops were intact on all)
New 6L getting the cam/springs/sensors etc...
will have pics later, I'm covered in oil right now
Broken pulley puller .....
Engine removed
#75
Quick update:
Engine removed
2 Broken rings on 1 piston, still pulling others. (ring land was intact on all)
Engine removed
