Wideband Install
#21
Here is an interesting picture from www.bosch.com about O2 sensors. They say a picture is worth a thousand words...
#22
single digit dreamer
this is a intresting question, i would like to know for sure. seems like at the dyno many people would be seeing the wrong numbers since they usualy measure at the tail pipe.
#23
Originally Posted by parish8
wich is the "02", since that is what the sensor reads? i am sure there are lots of changes across the cat but does what the sensor reads change?
No your absolutely right that you can put it behind the cat, depending on hardware used.... Higher end setups like the Horiba or Motec systems allow you to calibrate for things like that. Many of the sub-$700 units do not, and you must find the technical brief or white-papers on those sensors to find the correct operating Temperature for them.
On my past turbo'd cars, 12-24" after the turbo is what I did. Pressure affects readings too! Put it pre-turbo, and you will get different readings unless calibrated for such.
With it only costing about $10 to get a new bung welded on to your pipe pre-cat, post turbo. You should see what kinds of differences there are. I'll even paypal you $5 bucks to offset the cost for a bung and welding
EDIT: had to change a word to the correct term
#25
Pro M
I am running the Pro M wide band, love the compact size! I have my power signal coming from the fuel pump curcuit, that way the element isent being heated unless the truck is running.
Picture of display:
http://members.***.net/jredfearn1/100_3120.JPG
Of sensor in x pipe:
http://members.***.net/jredfearn1/100_3088.JPG
Picture of display:
GXPJAY
02-13-2022 08:15 AM
zblee
08-03-2015 03:45 AM
maxspeed05V
07-19-2015 07:08 PM
