Wierd vibration from brake pedal with cam..
Old 03-09-2008, 07:05 PM
sbw9056's Avatar
Originally Posted by BlownChevy
all three are things that are NOT going to change his problem.
You're right. They will only compensate for it.
Old 03-09-2008, 07:12 PM
joshua022's Avatar
Originally Posted by Nick™
somewhat true. The 2003 trucks have a vacuum pump on the brake booster that should compensate. Under other circumstances the vacuum can reduce the power of the brake booster.
can we get more description of the "vibration", is it while stopping, sitting at idle, does it change with the lope/ surge of the motor?
^^^ is dead on... My 03 does the exact same thing. does it make a humming sound when it vibrates??? if so then it definetly the vaccuum assist pump.(it feels like you have a cellphone set to vibrate in your shoe, I bet)
Aint nothing you can do about it but you will get used to it.
I put a vacuum canister in thinking that would help but it doesn't it may come on a little less often but it still does especially after a hard, fast stop.
Old 03-09-2008, 10:42 PM
03GMC's Avatar
Yeah thats exactly what it is. Nothing I can do? Great. Lol. Not too big a deal, I just don't like the humming sound it makes.
RustyD
05-23-2016 07:04 PM
turbo6c3
10-05-2015 06:11 PM
KINGCYCLES
10-02-2015 10:21 AM
01silvy
09-26-2015 10:20 PM
Alco
09-04-2015 04:08 PM
Quick Reply: Wierd vibration from brake pedal with cam..
